Hello,
I just got my antminer L7 and I didn’t expect the obnoxious noise on those fans. I am trying to build a DIY silencer box but I don’t think it will do much (tried it before on the goldshell lt5).
I was close to getting the minermaster pro-a+ immersion cooler (btw not sure if that link is legit) but it looks like it’s optimized for two single-fan miners. Would it be feasible to use it for the L7? has anyone tried putting a dual-fan miner in this thing?
You have to consider that as soon as you place a miner in there you void any and all warranties you had.
You would also be wise to look at fluid circulation. If you don’t y’all fry the chips in the middle of the miner.
There are many other options out there, people have built boxes, cabinets, used old non working chest freezers.
Either way you will need to consider how you deal with the ambient room temps.
I can offer a different option.
3D Printed shrouds that attach to the fans on the miner, you then attach flexible ducting you can pick up at Home Depot or Lowes. The ducting that also has the insulation around it. The higher quality R Rating the denser the material, so better noise reduction.
But doing this enables you to direct the heat from the miners through the ducting to a window for example.
I’ve personally done this and saw a 25db+ reduction. how accurate can a IPhone app be?
visit 3dps4u.com for the duct/shroud mounts.
