Anyone doing immersion mining with your ASIC miners? I have been researching this subject and find it intriguing. What is the ROI time frame in terms of energy savings, if any? I haven’t found a complete kit yet for small setups, 1-4 miners…Is there any recommendations for kit manufactures?
I have also been researching immersion we are in the process of putting together an immersion mining farm. Bixbit makes a small system but it’s pretty easy to build one out of acrylic panels if your handy working with wood. It’s works about the same. You just have to be sure to add a grounding plate in the tank and connect it to a ground or static electricity will build up and……POW! Shock you and short out your equipment.
Here’s a great resource.
Thanks @DJL !
I have watched several Engineered Fluids YT vids and this is what prompted me starting this thread actually. I own a manufacturing company and am handy with building things. Do you have a link to any plans for the DIY’er?
This being said, owning a manufacturing company has taught my several things including let the experts do their thing including buying ready built machines/setups like the Bixbit you mentioned.
Thanks again!
I can post the drawings I put together for my small test tank. However for my operation I’ve ordered the e hindered fluids gen 5 tank. It’s just a 2 month wait.
cryptotherm PIP and PH1 are in stock and ready to ship.
