Hi!
I have the opportunity to buy a A10 pro+ 750mz/s for about $1000
Will this be able to mine anything after the merge?
I’ve heard innosilicon will not support Etchash.
Is there any other coins that will make it Worth it?
CLO should pay about $6-$7 a day before electricity. If you profit $4 your looking at a 10 month ROI but you get to mine ETH until it’s all said and done which could net you the $$$ a whole lot faster if they drag their feet AGAIN!! For $1000, I’d buy it!!
I personally dont know the process, but yes you should be able to mine other coins that use the same algorithm. and yes for $1000, i would probably do it. keep in mind they are loud, create a lot of heat, and need 240v, and draw a decent amount of power.
