I am new to bitcoin and mining and I have a lot of questions. I believe decentralized currency is the path to our future and I would like to assist in its growth as much as I can. So here we go.
Is “futurebit” a reputable site to purchase mining equipment?
Most likely, but it really depends on your electric rate. For it to be profitable by 1 cent a day, you would need a 4 cent and that’s on low power mode.
long term it wont make you money. that being said if you believe in crypto future, running a node is an awesome way to support the cause. at worst you will make pennies a day if the market goes back. but either way its a relatively cheap and helpful way to support bitcoin.
some quick resources. but please double check everything. there are always scammers in the space.
bt miners easy website trustworthy, a bit pricey. best thing about their website is the earnings section Miners Profitability – BT-Miners
asicminervalue great for basic asic info and earnings, but a lot of their approved resselers are shitty companies, and some are scammers. https://www.asicminervalue.com/
whattimine great info on gpus, but their numbers tend to be off a bit. whattomine.com
vosk has a lot of cool info, but at this point i think there are better newb channels. check out this guys videos for a bit of fun and easy information. https://www.youtube.com/@WhiteboardCrypto
My electric rate is .13 kw/h.
I am using online calculators and with a electricity cost this high it seems to be not that profitable. Im looking into figuring out ways to reduce that cost
