Is it realistic to try to get a S19 Pro+ Hyd on release?
I’m a little new to this, the S19 Pro+ Hyd looks like the best rig out there, and I like the watercooling feature. Is it unrealistc for me to try to find a way to get hold of it for a decent price on release? or will the big miners already have it on pre-order/ or botters will get most of them ?
I highly doubt BitMain will even have them for order smaller than 100+ units, but the release date is January 2023. Are you sure you want to have your funds tied up for that long? Price of BTC could drop 50% by then and with it, the price of miners. My general to purchase from the secondary market at about 10% over.
Thanks for the reply, so which btc miners would you buy right now to run under solar ? lets say 150kw excess power
depends on what you are paying for the machines and how comfortable/handy you are with machine. There’s a bunch of good buys on second hand gear in China at the moment, especially if you aren’t paying for electricity.
But, generally I recommend buy new ASICs, S19s, and deals can be found at 75-85USDT per Th.
Go look for a trustable reseller. Bitmain only allows bulk orders on them, so you’ll need some entity that will take on the risk and buy up stock. As far as we know, every S19 Pro+ Hyd shipped are meant at the moment for B2B customers. It will definitely take a couple more months till they become available for B2C.
