Hi would like to know is it safe to clean a asic miner with a air compressor gun. Can it damage any internal part due to extreme air pressure.
I set my air compressor to a low PSI sometimes to clean my electronics, usually around 10-15 PSI. It’s not something that’s probably recommended but it’s worked for my mining rigs occasionally
just use short bursts with everything off. dont use a can to much at once or it can mess with equipment a bit.
Bitmain recommends it. If not using air compressor gun what’s the alternative
Compressed air in a can. That works ok but not as consistent as a air compressor
I use 30 psi. More on laptops and computers.
