Issue setting up new S19j Pro
I set up 5 new S19j Pro 104TH last night. Miner 1,2,4,5 all went fine. Miner 3 had already had TEST in the pool address, miner name, and password slots for all 3 entries when I first put the IP address in. Those were blank on 1,2,4, and 5. I erased everything and put the pool addresses in and miner names in for #3 clicked save, but going back to the dashboard still shows TEST? Has anyone had this issue?
Hmmmm never seen this before. Were you able to find out the reason?
Maybe try to factory reset it? I don’t know enough yet, but it’s just something I used before and you’re probably familiar with it. I had to unplug the power, hold the IP report button in and then plug the power back in and still hold the IP report button in. I only have S9s but a buddy of mine has an S19 J Pro and that helped him out.
I tried factory reset from the interface and the reset button on the machine. Nothing changed. I finally did a firmware update and that fixed it.
I have the same issue, except when I try to update the firmware via the web interface it doesn’t take the firmware.
