Hi there, I purchased my first ASIC and wanted to connect it to my dryer outlet in my apartment. I was having issues finding the plug. Would anyone have any suggestions?
I believe it’s a NEMA14-30P to 2 x c13, can’t seem to find it anywhere online. :S
Make sure to stay under 24 Amps. There’s a display showing voltage (should be between 205 and 245) Most big ASICs will be 14 Amps or less. You can pair bigger ones (S19 series) with smaller ones (E9 Pro, D9). (Size here is wattage, not physical dimensions.)
Try a NEMA 6-30P to 2 x C13 adapter. This adapter has a slightly different plug configuration than the NEMA14-30P, so you would need to confirm that it is compatible with your ASIC before using it.
If interested I have some tripplight equipment for sale such as meter PDU and C13 cables also, less than 2-3 weeks power ran on cables due to relocating to a host.
