Issues with L3+ on litecoin pool
I switched over to litecoin pool from F2Pool about a month ago to try it out, my X5 has been running very well on it with no issues. I picked up a super clean L3+ on ebay for a decent deal, probably two weeks ago, and it’s been hashing away. I went on my dashboard the other day and the L3 is making about half the LTC that the X5 is and the stale and invalid shares are about 4 times as high on the L3. The hash rate on litecoin pool is 850 mh/s on the X5 and 500 mh/s on the L3. I’ve never had this issue before so can someone help me out with what I need to fix with the L3?
I have a few L3s setup on Litecoin pool.
Not sure what problem you are asking to be addressed here.
If it’s the number of stale or invalid shares I would check your internet connection for the L3 as they is usually what causes my stale shares to increase.
If you are asking about the hash speed. Your speed is normal for an L3 (what was your performance expectation?)
If you want to “fix” that you can just overclock them but be prepared for higher energy consumption, higher fan speed (increase in noise), higher heat, and possible hardware degradation.
You can do this using any of the popular OS out there. HiveOS has an auto tune feature that can do that for you pretty easily.
L3 hashrate is only 504 unless your overclocking
I was asking about the stale/invalid shares sorry. I’ll try doing something with the internet today. They’re both hooked up exactly the same sitting right next to each other though but I’ll check it anyway.
