Jasminer-able to mine other coins as-is?
Curious if I bought some of these, whether or not I could use en to mine some other alt coins now that eth is effed
Asisminervalue says it can mine 6 other coins
https://cryptominer.deals/coin/callisto
This shows profitability on Callisto.
Google isn’t hard to use…
Which model are you referring to? If you are considering purchasing now, I would wait a few weeks and see how the merge works out. There is going to be a lot of mining firepower directed at ETC and similar coins. The profitability is hard to predict.
ETC and other 11 coins. You may refer to the link as blow and know how to do the relevant setup on your Jasminer X4.
My mail : nico@jinglemining.com
