Just starting out
Hey guys!! My name is Tyler and I’m new to the crypto mining world. Im from Nevada too! I saw that one of the more active members of the community is from here. (Kinda cool) So, I stumbled across Vosk YouTube videos and I’m pretty stoked to get into mining. I have watched pretty much all the videos and have done hours of research but I have so many questions that I haven’t been able to find the answers to. I’m hoping the community is as helpful as Vosk has mentioned and I’m hoping that I too can contribute to the community in time to come.
So my first question is, after getting the appropriate voltage of electricity and Ethernet cable is there anything that through your own experience that you can perceive as an obstacle? I am trying to compare all the miners in an objective manner and think I am going to order the KD6. I want to have the setup ready so when the miner gets here I can plug it in and start. Also, there are a few sites that sell. It seems that there may be more fraudulent sites than legit sites. Is there a consensus on the best site to use? Also, with the crypto market looking bearish right now, do you believe that the miners will drop in price? If so how long of a lag do you think there will be before this is reflected in real time?
Any input would be greatly appreciated. Thank you guys! :slight_smile:
Also if you feel like there is a better miner out, or why you chose to mine a different rig. I would also like to hear about that! Thank you.
Personally I designed and printed 3D Printed ducting that attaches to the miner fans and enables you to connect a 5/6/7/8" ducting to the miner, Then you have a vent in your window. This way the heat is blown out the window away from your miner. The cooler you can keep the room the Safer it is, but it’s also beneficial to the equipment as well.
My eBay store
Email sales@3dps4u.com
Well ,I don’t think there is a website hold KD6 in stock, but you could try some miners else like iPollo V1 mini ETC miner from POWPOWER
And i just received two of them this month.
I’m in the same boat. At least I grasp computers, networking, system admin and electrical wiring in homes. I’ve done it all. The trick is getting that first miner. I’m looking into seeing if I can get a loan to buy one or two of the big miners through my LLC. It still feels risky though.
I wouldn’t invest money u don’t have it normally not a wise choice
I understand. But if I buy under a business my personal finances aren’t at risk. I’ve had to play around e we itch finances all my life. Had I not done that we wouldn’t have what we have and my children would not have been able to stay home with my wife or me. I’ve been a home dad since 2010. Was an engineer. Long story that would bore you.
You must be the same person who got banned about a month ago for constantly spamming your website. You follow the exact same pattern as that person @Ted_Virtus @VoskCoin
Is www.asicminervalue.com a good site to base authenticity off of? I know Vosk uses their site in his videos to display specs. From what I can tell most of the sites are legit and the site displays a bunch of “trusted vendors” at the bottom. It would seem after searching through this forum that most of the sites displayed are legit. The one I was looking at in particular was AKMiner and it says that they are in stock. Do they normally not have them in stock even when they say they do?
Good to know. Thanks! :slight_smile: The profitability of the miner he was suggesting makes no sense right now.
