Hello! I’m very new to mining and have two questions. I bought an EVGA gold 750 W PSU and want to make sure I’m powering it correctly.
I believe the KD Box uses 205W. Does that mean I can have a max of 3 on one PSU?
2.I’m very aware that the KD Box takes a 6 pin connector. But I’m not sure which slot to plug it into on the PSU? And do I use a 6 or 8 Pin connector for the PSU?
Yes, the 8 pin PCI-E connectors on the power supply should be used. The other end of the cable should have a 6+2 (8 pin) connector or two which goes into the KD Box.
I am also wondering about how many KD Boxes can be connected to a EVGA PSU. I have an 850W G5 so would i be able to connect 4 boxes ? that would be 4*205W which is less than the PSU max watts but im not sure about the amps drawn by the boxes and if 4 boxes connected to the 4 VGA outputs on the PSU will draw too much amps ? If anyone knows ?
