KDA mining solo on a private node
How many KDA per day on each unit with this oldy but goody server?
Ive had as few as 4 but as many as 17 (edited for todays haul, haha!) on one K1+ per day running thru an older HP machine I use for my Chainweb/Docker Node
here’s a pull, in current dollars (KDA = 5.46)
Date $ KDA
02/02/2022 $52.37 9.59
02/01/2022 $87.29 15.99
01/31/2022 $52.37 9.59
01/30/2022 $64.01 11.72
01/29/2022 $58.19 10.66
01/28/2022 $99.00 18.13
01/27/2022 $81.71 14.96
01/26/2022 $64.20 11.76
01/25/2022 $64.20 11.76
01/24/2022 $58.36 10.69
01/23/2022 $11.67 2.14
01/22/2022 $70.03 12.83
01/21/2022 $75.87 13.90
15 nice. As you probably know the average im getting on PoolFlare is from 10 KDA with my IBELINK +1 on a good week.
I have a new laptop that should be more than capable of bridging a node for my server.
I would rather gamble a reward of 2 KDA than lose a reward increase of an extra 5 KDA a day.
On average even with the 2.14 and the 9.59’s. You still get 11 KDA minimum as a worse case scenario.
Again 10 KDA is my best scenario.
Here is where I’m at on my test – solo is only ~0.32 KDA better. I’m letting it run the whole month. I have one K1+ on PF and one K1+ solo:
Solo_vs_PF_K1+
excellent analysis.
@Thorn In the 1/21 - 2/2 table that you posted, what’s your total hashrate? Earlier post mentioned a KD5 plus 2 KD-Box, which would be 21.2 Th/s (18 + 1.6 + 1.6 Th/s) total. Is that the hashrate that your table represents?
I was going to put together a chart of KDA/day for Thorn (solo) vs gavtronzero (solo) vs Zilina (Poolflare) but I’d need to normalize hashrate so that the chart would be apples-apples-apples.
@gavtronzero You mentioned that your chart represents a K1+, which is 15 Th/s, right?
So if my understanding is correct, I’d have to normalize gavtronzero’s and my results (one KD5 @18 Th/s) by 21.2 / 15 Th/s = 1.4133 and 21.2 / 18 Th/s = 1.1777 in order to compare yield on apples-apples basis with Thorn’s.
Following.
All correct assumptions for me – if you want to really get into the weeds, you can use the average hashrate for each individual machine. My PF K1+ is averaging 15.69TH and the solo K1+ is 15.48TH.
@Zilina there is an early peak, that’s when I added the two kd-boxes to the kd5, so yes, theoretically 21.2, but closer to 17.7+1.6+1.6, but hey, who’s counting every transaction, dating it, noting the block, the txid, the time, the request key? Me? well, yes…what else am I gonna do?
There’s only so many times I can count the KDA I have, where I locked, pooled, or stored it.
@cryptominernv @Winston @T7LY @Zilina @JoeJoe @SteveB
I wanted to update the past month, so here 'tis and my specs are one KD5 with two KDbox miners on a private node running on an old laptop (not that old, really) but anyways…dang it, my graph doesn’t upload, well, you get the idea…
sumDate kda sum
01/21/2022 13.895765000
01/22/2022 12.826862450
01/23/2022 2.137810000
01/24/2022 10.689050000
01/25/2022 11.757957450
01/26/2022 11.757963450
01/27/2022 14.964712130
01/28/2022 18.131631630
01/29/2022 10.658266660
01/30/2022 11.724069500
01/31/2022 9.592420500
02/01/2022 15.987436450
02/02/2022 9.592420500
02/03/2022 13.855722500
02/04/2022 17.070599240
02/05/2022 17.053192000
02/06/2022 14.925707620
02/07/2022 12.789910900
02/08/2022 13.855738400
02/09/2022 23.448326310
02/10/2022 11.724075500
02/11/2022 18.120374850
02/12/2022 19.184841000
02/13/2022 14.921543000
02/14/2022 9.592431400
02/15/2022 11.724676850
02/16/2022 9.593029350
02/17/2022 14.948053000
02/18/2022 14.921549000
02/19/2022 21.316490000
02/20/2022 15.987614200
02/21/2022 11.724080400
So very little, to no, difference from mining on poolflare. On average.
13.76482254, on average, for the past month
  • I have played a part in the decentralization of the blockchain—at least, that’s what I tell myself.
