KS0 Pro fans will turn on but 0 hasrate says connected to pool please help
Is this your first miner? It can be a bit confusing at first. I think I mined the first day or two before I realized my error. You can connect a miner to mine to a pool, but if you haven’t gone to the pool site and set up an account you aren’t going to be stacking those coins. Think of the pool site as the temporary place where your coins will be placed. You can transfer them to a cold wallet later if you’d like but you have to have a destination designated for the coins to go once they are mined.
Here is a video that will help with setup if this is your first rodeo. You can use any pool this is just the video that I used to assist in setup. https://youtu.be/xqD6d1MYT-U?si=s1z-O03DpbpZsTWz
