L7 network status abnormal? Red light blinking
Any suggestions on what i need to correct this issue? My brand new L7 with the newest firmware update is blinking red light and according to the stats provided on the dashboard it is saying the network status is abnormal. I went ahead and reset my modem and router but no changes. It is also not showing up on my dxpool account. Any help will be greatly appreciated.
So im still a newbie but am keeping this post instead of deleting it to maybe help someone in the future out. I did not properly fill in my dxpool information in the dashboard of the L7. So when it was saying there was abnormal network issues, i should’ve investigated my typos first then hardware.
Thankfully easy fix
Hey bro,
I have been getting the same error. Tried to triple check the details they should be correct but I keep getting the same error where it says abnormal and blinks in red!!
Help plz
Are you using DxPool? Like I stated it was my typo that had me messed up. In the L7 dashboard you need to have your DxPool address and the miner name needs to be whatever your DxPool accounts name is. This is what I did incorrectly, I didn’t use my DxPool account name. Hope this helps, if it doesn’t then I would start checking my router connection and internet speed.
