Hi. I GPU-mined a little 3 years back and stopped when my .14/kwh rate put me in the negative<-probably should have just let it run
Looking at the field again, here are my questions:
- Are there any profitable miners available in the $500-$1000 range? Everytime I look up prices, the links, example-> https://www.asicminervalue.com/ add several hundred dollars and often not in stock. Mostly looked at Goldshell and IceRiver.
- Can one set up a mining business and get a lower electricity rate? If so, I’m assuming it involves another physical structure with power (like Vosk’s in the videos) - the criteria being it’s own meter?
- For those with different devices/OS, are you able to monitor them in 1-2 apps (like HiveOS)?
Thank you in advance.
