LT5PRO not working :( HELP
Hey Guys!
So unfortunately my LT5pro has stopped working.
I have tried all I can think of, but still nothing…
Does anyone have some advice or helpful opinions? I would be extremely greatful! :smiley:
Happy to provide the miner debug list if needed, emailing might be best.
HAPPY MINING!
you can send to BT-Miners to repair
Most likely a Power Supply issue. If you have another power supply that will fit it from another miner, Attempt that. If its still under warranty Goldshell will send you a new power supply once you have tested it if you open a ticket with them. Seems like there are a lot of power supply issues with the LT5 Pros.
Have you tried restarting or resetting the miner? Or try using another control board.
Apparently the PSU is fine? May be a control board issue?
control board issue.
i have reflashed the current CB but nothing changed
