Mini Doge 2 only hashing 70mh/s possible causes?
I just got a new mini doge 2 from crypto miner bros and it doesn’t seem to be performing as it should. Its all set up and running on dxpool but over 12 hours have only mined 0.6 doge and 0.0003 ltc. It wont run higher than about 80mh/s and the average is about 69-70.applying Low power mode does not appear to change the hash rate. Could this be an internal issue or something that can be easily resolved?
Maybe ask the DX pool support?
I have one, I think mine ran straight out of the box…
Goldshell support is good as well I believe
Good luck, Steve
