Just got my new mini miner hooked-up and everything is perfect. Just follow the Voiskcoun videos on this machine (4 total, I think) and you’re good to go!
Major shout out to @Aaron_Raycove up in Montana, the CEO of Big Sky Miners for the machine and advice. Check out his profile for contact information. He’s the real deal, super-nice, and can get the impossible. Thanks, Aaron!
If you’re looking to use multiple mini’s I definitely recommend the bitmain apw7 psu’s, you can run about 8 minis off the one psu. If you’re just doing one then you can grab a 400watt atx psu off newegg for $50.
Looks like a bitmain psu based on the picture shown.
If you are going for an ATX power supply you can run 3 Box miners off of an 850w for about $100. I got this one on Amazon. I wouldn’t run more than 1 miner off of each cable but it comes with cables to power up to 4.
You’ll have to follow Goldshell’s article about how to start up an ATX power supply if you go this route. Like Aaron said an apw7 is a solid choice too.
@Deadhead You can, but the Mini-doge takes a 6-pin for power; any power supply that has a 6-pin power connector will work. To make things simple you can just get their psu and not worry about it any further.
