Mini Doge I can’t figure out what happened
Hello All, I am hoping someone has a suggestion for me. I have a few Goldshell Mini Doge miners. Up until today they all worked great. Today 1 became inactive. I deleted it from F2Pool and reset the miner now I can’t get it to connect to any pool. I’ve tried 3 different pools. I have the most recent firmware and I have reset it a ton of times. All the lights indicate it working. Anyone have any advice?
so im kind of in the same boat. I added 2 miners to dxpool this afternoon. 1 is in the pool and the other is mining but not connected to the pool. Ive copied the addresses correct but still only one is on dx pool. so weird and im now on hour4
Did you change the names for each machine? If you set the worker name the same on each unit it may combine them and not list them individually. I only have experience with GPUs but could see this as a possibility. Check the reported hashrates.
Thanks for the suggestion. I did they are all named something different. This one won’t even show the hash rate on the admin dashboard for the miner.
matter of fact, i havent changed the miner names but the 1 miner reads 500gh/s so that would make me think there are 2 at 250 gh/s hns
After you reset the miner did you do a new search since the IP address changes after a reset?
