Goldshell has completed their new BOX II home-oriented mini miners line-up with the release of the KD BOX II , CK BOX II , SC BOX II ,MINI DOGE II miner that is now available. Last time we focused on KD BOX II and its advantages. Today, I will [introduce](javascript:
other BOX II Series Goldshell MINI DOGE II
The new Goldshell MINI DOGE II ASIC miner, much like the other BOX II devices, comes with dual operating modes — 420 MH/s at 400 Watts or 355 MH/s at 260 Watts for the Scrypt algorithm.
The device can merge-mine LTC and DOGE simultaneously or any other Scrypt-based crypto currency. The new Mini DOGE II miner comes in the updated slightly larger and heavier form factor compared to the older MINI DOGE PRO devices and with dual 6-pin PCI-E power connectors due to the increased power usage, just like the rest of the BOX II product line. There is a slight improvement in terms of efficiency for the higher hashrate mode where you get 0.95 Watts per Megahash (compared to 1.1 Watt per Megahash for the MINI DOGE PRO), but the more interesting efficiency wise number is in the low power mode where you get 0.78 Watts per Megahash in terms of power usage.
Description
Model Mini doge II from Goldshell mining Scrypt algorithm with a maximum hashrate of 5T for a power consumption of 400W
Specifications
| Manufacturer | Goldshell |
| Model | Mini-DOGE II |
| Release | March 2023 |
| Default Hashrate Mode: | 420MTH/S±5% @400W±5% |
| Low-Power Mode: | 335MH/S±5% @260W±5% |
| Size | 178mm150mm84mm |
| Weight | 2.3KG |
| Noise level | ≤35db |
| Fan(s) | 2 |
| Interface | Ethernet/Wi-Fi |
| Temperature | 5 - 35 °C |
| Humidity | 5 - 85 % |
Advantages:
Another Powerful Home Miner for DOGE & LTC
Goldshell presented a new home miner mining both DOGE and LTC,Give more options to mine one of the most,popular cryptos in crypto world.
BOX 11 - The Best Options to mine at home
Goldshell Box II presented two different modes for customers to choose
BoX is the best option if you want to mine at home ,You can put everywhere in your house . SMALL and QUIET are the advantages of BOX II.Also, low-power mode can help you save more, earn more
Exquisite Body Design
The whole miner is delicately designed. which is safer and more convenient. At the same time. the compact size is also easier to place, saving space
Advanced Dashboard
Convenient to observe the real-time hashrate Average hashrate and hashrate fluctuations. Providing a user-friendly mining system.
In terms of efficiency even in the low power mode the Goldshell MINI DOGE II is still very far from what the latest Bitmain Antminer L7 Scrypt ASIC miner is able to offer, but not everyone can afford an L3 or be able to run it due to its high-power requirements. Goldshell MINI DOGE II comes as a more affordable, even though not the most efficient solution, that you can easily run at home or in a small mining operation. It is pretty silent and easy to operate, placement around the home is easier if using WiFi connectivity and can be used as a compact home heater that kind of covers the whole electricity it uses (depending on your electricity costs) at the moment. If you are interested in it .you can buy it through our official website :www.apextomining.com .Contact our sales and we will also apply for some discounts for you.
