Mini doge miner cooling
normal fan + Artic P8 fan upgrade!
Temperature
Before 77~78 °C
After 62~63 °C
I’m curious as to why you added fans? I run mine stacked on top of each other with no issues
I have extra fans so I added them. It was designed to withstand high temperatures, but in the long run, I thought it would be better if the temperature was even a little lower.
That mini doge looks badass not gonna lie!
Can you tell me which fan for mini doge did you get?
I have a s19 pro sitting under mine and it’s running 77.1 at 1380 rpm with a hash of 187-194 MH/s. Did you notice it running any better by adding the fans?
