Mini doge miner - Help! Troubleshooting!
Hi,
I received my first ever miner today but something seems wrong…
Or maybe it is just me who can’t figure it out…
I’ve got the following indicators:
At startup:
Above ethernet-cable: Steady green and blinking orange
Above power-cable: Steady green
Top of miner: Blinking red
All that seems fine but after running for about 30 sec the following indicators show:
Above power-cable: Steady red
Do anyone of you know what the problem is? I’ve tried to start it over a few times but the same problem accure…
I’ve figured it out! ;D
I’ve got basically the same issue. What did you figure out? I have the wireless version and can’t access the miner admin page…
”cryptominernv” wrote the following:
Ok, i think I might have figure this one out. I was experiencing the same problem as you on my very last kd box set up just couple minutes ago. I’ll write it step by step for easy understanding. I hope this helps. Let me know if it worked for you or not.
  1. Go to your wifi network and connect to your goldshell box (KD,CK, or what ever you see on your network). You will be immediately disconnected from your wifi network.
  2. Type 192.168.0.1
  3. Access your portal and change the language to English
  4. Unlock your BOX
  5. Go to systems and look for your wifi that you use everyday and connect.
  6. Type in your wifi network password
  7. Now the BOX should disconnect itself and immediately connect to your own network
  8. Now go to find.goldshell.com and locate your miner. click on the little hex on the right
  9. This should immediately take you to your personal goldshell dashboard
  10. Now go add your pool information and save it!
That’s it! This is how I was able to fix the problem you are facing now. I hope this helps!
PS. I was able to connect to 192.168.0.1 even though the internet showed NO CONNECTION. Give it a shot
There’s also a Goldshell document that discusses this. It’s about half way down this document. I don’t know why Goldshell doesn’t print this and put it in every wireless Box miner…
Thx for the update. I have been looking at ALL the Mini Doge miner posts before buying. This is the only post I have seen mentioning this…
Is this for mini doge on a wireless set up?
