Mini doge problems with prohashing .com
hi everyone my first post
i have some mini doges on pro hashing mining pool from day one,last month i have been getting all sorts of miner errors ,kept rebooting miners starts hashing at 185 as normal then they drop to 90 m/h and i get more alerts from pro hashing .i started to think all my mini doge miners were giving up life.
so last resort i changed to dx pools and omfg all working as they should be no more errors and I’m getting loads more coins each day ,i guess some mining pools are not as good ,learnt my lesson the hard way . any one else had probs on prohashing .com ?
I myself use f2pool and DxPool and they both work very well.
Sounds like you found the solution to your problem.
f2pool and DXpool are popular. Personally I use DXpool.
The symptoms you describe could also be a firmware issue. I had problems with one of my mini-doge miners and contacted Goldshell for support.
Turns out it needed a firmware update and has been good ever since.
