My two mini doge miners are offline on F2Pool and not mining since 1 am. Everything appears to be working normally if you look at the miners - fans are on, blue lights blinking fast as they should for normal operation. However, when I go on find.goldshell.com, they no longer appear. The page is just blank where my two miners and their IP addresses used to be.
I tried shutting them down and turning then back on and that didn’t do anything. It also doesn’t look like there’s an update.
Any ideas?
