Mining 2 different coins
Hello,
I was wondering if it were possible to mine 2 different coins in 2 different pools with 2 GPUs on 1 motherboard? I’m really enjoying the wealth of information, and the willingness to share in this forum. Thanks!
Sure. You can download 2 different mining softwares and set the first config file to GPU0 and the secong file to GPU1
Great! Thank you for the help. Is there a particular software you recommend?
depends on the cards you have and the coin you want to mine. you could tell me whisch cards you use and what coin on what pool you want to mine then i can give you the mining programs
