Hello all
I’m mining using Hiveos with only 73mh so I do understand not a big rig but just learning and enjoying doing it. I’m using nanominer one coin ETH on Hiveon pool and the other ZIL on Ezil pool. I understand every 90mins for 1min so not going to see much but I have not seen anything at all in 2days. Could I have something wrong maybe not set correct I never see Ezil dashboard ever show a worker but Hiveos shows the ZIL MH in a box after each run.
Thanks
Wayne
I did the same thing. Once I changed the wallet format it showed up on the ezil pool website.
In your HiveOS ZIL wallet, use both your ETH and ZIL addresses together separated with a period “.” ETH first, then ZIL. Like this:
0x222222ETH222222222.zil333333333ZIL33333333
Since your’e using hiveon for the ETH pool, the active workers only show when ZIL is processing once every 60-90 minutes or so.
What card u using a AMD or Nivida? On my AMD I got it working great but as u know the site acts strange not showing ur money on every pass maybe because its so small a amount for me. Teamredminer ETH+ZIL Hiveon/Ezil (RX570 8gb) needs a command line arguments that tells it to watch and both wallets eth.zil plus both mining addresses in pool site setting. My 1660 super 6gb with phoenixminer I’m going to try again may need a dag command or something not sure.
Wayne
I found 5 Zil in my fund @ Ezil from using Nanominer and not thinking it was working.
When mining Zilliqa on a different pool, nanominer will use a placeholder 0xffffffffffffffffffffffffffffffffffffffff ETH/ETC address to authorize on Zilliqa pool.
Wayne
Zil block chain been broke all night and all day today they said they r working on problem, just when I got all running good.
Wayne
