Lets say you are located in a remote part of the world such as Alaska, Hawaii, Bahama’s etc and you do have a solid internet connection. Will this distance effect the ability to mine quickly. For example compared to an identical miner of the same TH/s that are located in a large city?
Latency could possibly affect solo mining, pool mining no not in an obvious way for sure. As long as its not ultra-high latency like 300ms you will be just fine, and like I said it really only affects solo mining, and even that is negligible if any.
