Wondering if there are any coins worth mining? Ive got 1 1070ti, 3 1060’s, 2 570’s, and 2 560’s
KAS This coin mining is highly profitable.
AMD’s and Nvidia’s are typically profitable mining different coins. For your 1070 ti and 1660, your best bet is currently SWAP. Your AMD cards aren’t really profitable but I’d go with Ravencoin. The thing about GPU mining is that you have to check often to see what’s profitable because it‘ll change
As stated by @Krisz use whattomine.com or hashrate.no (I use hashrate.no becuase it has more low mc coins)
And it also shows you good overclocks.
Yerp. Generally need a BIT of tuning but I can usually get them to work as stated or above. (I got 31.6 mh/s on kawpow on my 3070 they said it should be like 30.5 or something like that)
