Hey Guys,
I am planning to start mining with my new cpu using rtx 3080 do you think its really worth it ?
Hey Guys,
It depends on your electricity cost.
0.15 eur kWh
It’s worth it. Get the a free Minerstat for Windows account to mine the correct way with an easy to use interface.
if i may ask do u really get some profit after the pool fees and electricity ?
YES
I recommend NiceHash
I reccomend against renting your hashing out on Nicehash and instead get yourself an actual blockchain wallet and mine on an actual pool. Minerstat for Windows makes it easy.
