I finally received my Blackspot, now I am wondering what to do with the SD upgrade kit? do I just swap it out for the other and I’m good to go?
I’d reach out to their discord. You should definitely find your answer there
I swapped it out on mine and it worked as is. make sure your powered off before doing it. Also some people had to flash the card and download the firmware back on it but that’s rare that it will happen
