Mounting Helium Antenna if you are a renter
Hello Vosk! I wanted to know of creative tips to put a Helium Antenna on the side of a house if I am RENTER. I can’t drill any holes. Thanks in advance.
What type of dwelling is it? House, Apartment, duplex?
I’ve seen people strap a pole to the side of their chimney with ratchet tie-downs, no drilling needed. That gives the best elevation. You could just build a free standing antenna tower but that’ll be more costly and more thought put into it to figure out stability and height.
There are magnetic antenna mounts…If the apartment has a metal roof, just stick a mag mount on it, or you could do the same thing, with a piece of metal on one side of a window, and the mag mount on the other.
