This Goldshell Byte mining rig is kind of like a GPU mining rig for the modern mining era, reducing waste allowing you to swap out ASIC cards to mine different cryptocurrencies and update the miner later but uh, is it actually worth buying and how much does it earn in mining profitability? Iād buy this instead to mine BTC - NerdQaxe++ August batch PREORDER ā Power Mining
Buy full-size miners and also the BYTE here - Asic Marketplace: Most Reliable Asic Miner Shop - Asic Marketplace
Cheaper mini wifi bitcoin miner option - Bitaxe Gamma ā Power Mining
Check mining profits here - Discover Asic Miner Profitability in Real-Time | Mining Now
Goldshell shop - https://voskco.in/goldshell
Cool mini bitcoin miner with a screen - Braiins Mini Miner - BMM 101 ā Braiins Store
Check out mining luck on SoloLuck - https://www.sololuck.com
From mini dogecoin mining to aleo mining to other ASICs in the future like maybe Bitcoin but probably altcoins like nervos network ckb kadena KDA and other cryptos the Goldshell Byte is a multi coin multi algo ASIC cryptocurrency mining rig
00:00 Mining multiple coins with the same miner
01:23 What is the Goldshell Byte?
03:41 Power adapter specs for Goldshell Byte
04:49 Inserting the DG card for Dogecoin mining
05:43 Inserting the AE Card for Aleo mining
07:22 Powering up the Goldshell Byte
08:11 Pros and Cons of the Goldshell Byte
09:18 How much does the Goldshell Byte earn?
10:37 Cost of buying a Goldshell Byte
12:14 My thoughts on the Goldshell Byte
Multi-Coin Mini Mining Rig - Change the ASICs like GPUs! Goldshell Byte Review
