Multi protocol pool software
Continuing the discussion from Bitcoin Knots full node:
have decided on using ck-pool on the node and also using public-pool for my solo miners, they use very little resources memory and cpu wise, should not be a problem, still looking for a multi protocol mining pool software, kaspa, bitcoin cash, etherium cash, other coins too
if i can figure out how to program the .json files for other coins might be tempted to try using MINING CORE, looks like it is multi coin and multi copies can be run on one machine, programming not my strong suit, not affraid to try, what is there to loose, would try on seperate machine as a pool server, got 5 of the x58 5650 motherboards 6 core 12 thread seems to work fine as bitcoin knots node, just need more research
just setup a UMBREL bitcoin node with public pool so i can mine to it solo till i figure out the multi algo pool software, 1 tb boot with 2tb data drive on an i5 intel setup
