Today I am setting up my own Bitcoin immersion mining farm, this is liquid cooled BTC mining, which allows for higher Bitcoin mining profitability, and spending less electricity mining earning more passive income! How easy is the DCX enclosure and dry cooler install? I’ll show you lol! Start mining yourself today here - Evergreen Miner v2.5 VoskCoin Tails Edition
Learn more about DCX immersion mining options - Home Immersion Mining Systems - DCX Liquid Cooling Company
VoskCoin Mining Farm Tour video playlist - https://youtube.com/playlist?list=PL4dnwHTjcf-8SXMDAoL7-XFkV6b4XUH3j&si=BD6oDOgXluoXOvnM
Buy your own Bitcoin miners here - https://voskco.in/am
Altair Tech PDUs and BTC ASIC parts - Altair Technology – Bitcoin Mining Solutions – Bitcoin Miners, Parts & Accessories.
Evergreen plug and play low power miners! shop – Evergreen
Use code VOSKCOIN to save some COIN!
I have toured some crazy Bitcoin immersion mining farms over the years and thanks to DCX I am finally going to start immersion mining Bitcoin myself! DCX has a plug and play immersion mining setup, they have options for single phase electricity and three phase electricity, in this video I am installing DCX immersion mining kit in my single-phase bitcoin mining farm. I also use Braiins s19 firmware which supports immersion mining because I did not have fan spoofers which are needed to when Bitcoin ASIC mining rigs are running in a liquid without fans. While this isn’t a step by step installation guide, hopefully this helps anyone feel more comfortable doing a DCX immersion mining farm build. If you have questions just leave a comment and I’ll try and check back and help with what I learned setting up my own liquid cooled immersion bitcoin mining deployment!
Contact BMA Enterprises crypto division here - BMA Enterprises - Crypto Division Home Page
00:00 Setting up the immersion bitcoin mining shed
00:40 Immersion mining is crazy Quiet!
02:25 Make sure your miners are clean before you immerse them!
03:27 Installing a different firmware on the Bitmain s19
05:37 Installing the DCX dry cooler
07:49 Manually Pumping the coolant
09:31 Using shrouds on the Bitcoin miners
11:00 Pouring the immersion fluid into the DCX immersion tank!
12:46 Turning on and opening al the valves
14:06 Powering the Immersion setup
15:22 Using the Altair pdu
17:14 Fixing bad miners
18:00 How is my wire management?
19:50 Installing the new Altair PDU’s
22:37 Should you immersion mine at home?
25:25 Using a transformer for electricity
26:11 Get connected with the community!
27:00 Thanks to BMA for helping!
28:06 Immersion mining is nice and quiet!
29:40 Make it happen!
Follow us on our official social media accounts - VoskCoin(VoskCoin) - Latest Storefront, Videos Links
My Own Liquid Mining Bitcoin Farm! DCX Immersion Installation and Review
