My RTX rig is only getting me 2.8 dollars with 240mh/s, and my other rig that produces only 190mh/s gets me 4.6 dollars. why and how does this happen?
without seeing all the info its hard to say, but most likely it lost connection for a while and the 24h estimate is off because of that.
Without question your rig with the higher hashrate should be earning more assuming you’re on the same algorithm. Give it sometime to see if those numbers adjust. After a few days you should have a more precise number on your earnings
My first question was are they on the same algorithm as hashrates are meaningless when compared between different algorithms.
What software is this in to make sure we cover any issues of reporting mysteries specific to that software.
