Need advice on the best mining setup
Situation: I have four acres of land that I am setting up my power generation farm. I will produce 50k watts daily from wind, solar, and hydroelectric power. What mining setup will give me the best ROI?
If 100% of the mining is powered from off grid sources then it is just a question of what miner generates the most crypto per day of any cryptos you wish to mine. If you want the straight up most dollar per day value you can find most of the info on various sites which I would look at the numbers from multiple sources.
Thanks for the response. Cost of the mining equipment is not an issue. I just need the best most powerful equipment.
check www.whattomine.com go to the miners part put in your electricity and there you have it
