Need help geting my S19 PRO GOING
Hello everyone I’m new to mining and a big fan of the vosk coin youtube channel. I recently purchased a S19 PRO. when I run the miner the Dashboard is reading REAL HASH RATE ABNORMAL. Can someone help me get though the process so i can get my ASIC MINNER making me money please!!
Thank you
please post a screenshot of your settings.
Hello @youngbuck
Did you get this resolved? It can be for many different reasons and some of those reasons will resolve on their own (Perhaps a network issue etc.).
If you still have the issue, please can you let us know what it shows in the dashboard for each hashboard? Are all 3 boards hashing? If it shows one of more of the hashboards as “abnormal” are all the chips hashing on that board? If you click onto the green/red square to the right of each board in the dashboard you can see an overview of each chip.
If they are red (Abnormal), the only way to troubleshoot this would be to take a look at the logs. If you are happy to share the logs feel free to do so, however this is upto you.
Note that Bitmain do have a support forum too if you would feel more comfortable with them directly. Their support/tech team is quite helpful.
Hope this helps,
Horus.
Hello
Thanks for the help I was able to troubleshoot it and get it working just fine. I’m trying to get it set up for immersion cooling, but i can’t find a fan simulator for the s19 pro what can i do to make it work in immersion cooling.
Hello I am quite versed in immersion cooling, What you need is a fan spoof or emulator that lets your Antminer think there’s fans running. I recommend DCX immersion cooling in England Beeminer in Russia, or Engineered Fluids in Texas. Anyone of those companies has the four pen fan emulators. You can Google them. Make sure you use high-quality dielectric fluid.
Do you have any other questions hit me up.
SAME PROBLEM, HERE IS MY LOG: Thanks
https://pastiebin.com/60bab40546b96
Hey I just joined and have questions. I would rather talk over the phone so my questions could be answered alot faster. Anyway I am thinking about purchasing the Iss A10 Pro? Theres an ad for $3400. Dont know if that’s a good price or if the company has a good reputation? My cell is 509.431.7910. Wes. Thanks.
hi i have a same problem with s19 pro. after restart or reboot works fine but after half hour or so loses the hashrate to zero and chips become abnormal. its only 5 months old miner.
i appreciate any advice
here is my log
free_area_init_node: node 0, pgdat c0b3c040, node_mem_map cde10000
Normal zone: 480 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 61440 pages, LIFO batch:15
percpu: Embedded 12 pages/cpu @cddf0000 s19916 r8192 d21044 u49152
pcpu-alloc: s19916 r8192 d21044 u49152 alloc=12*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60960
Kernel command line: mem=240M console=ttyPS0,115200 ramdisk_size=33554432 root=/dev/ram rw earlyprintk
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 209672K/245760K available (6317K kernel code, 243K rwdata, 1932K rodata, 1024K init, 232K bss, 19704K reserved, 16384K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xcf800000 - 0xff800000 ( 768 MB)
lowmem : 0xc0000000 - 0xcf000000 ( 240 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc090e410 (9242 kB)
.init : 0xc0a00000 - 0xc0b00000 (1024 kB)
.data : 0xc0b00000 - 0xc0b3cda0 ( 244 kB)
.bss : 0xc0b3cda0 - 0xc0b77024 ( 233 kB)
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to cf800000
ps7-slcr mapped to cf802000
L2C: platform modifies aux control register: 0x72360000 → 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 → 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at cf802100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
ps7-ttc #0 at cf80a000, irq=18
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency… 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100058
CPU1: failed to boot: -1
Brought up 1 CPUs
SMP: Total of 1 processors activated (666.66 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ps7-ocmc: ZYNQ OCM pool: 256 KiB @ 0xcf880000
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Trying to unpack rootfs image as initramfs…
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 6632K (cd480000 - cdafa000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=16 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.ps7-dma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 159, base_baud = 6249999) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to cf86e000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
CAN device driver interface
gpiod_set_value: invalid GPIO
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 31 (00:0a:35:00:00:00)
Generic PHY e000b000.etherne:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0005000.ps7_i2c: 100 kHz mmio e0005000 irq 154
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
nand: disable subpage write
nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
nand: Micron MT29F2G08ABAEAWP
nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
nand: NAND_ECC_HW
nand: NAND_ECC_HW_SYNDROME
mtd->writesize = 2048
ecc->strength = 1
ecc->size = 2048
chip->ecc_strength_ds = 4
chip->ecc_step_ds = 512
nand: WARNING: pl35x-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
8 ofpart partitions found on MTD device pl35x-nand
Creating 8 MTD partitions on “pl35x-nand”:
0x000000000000-0x000002800000 : “BOOT.bin-dts-marker-kernel”
0x000002800000-0x000004800000 : “ramfs”
0x000004800000-0x000005000000 : “configs”
0x000005000000-0x000005200000 : “sig”
0x000005200000-0x000006000000 : “reserve1”
0x000006000000-0x000007000000 : “upgrade-ramfs”
0x000007000000-0x00000a800000 : “upgrade-file”
0x00000a800000-0x000010000000 : “reserve2”
nf_conntrack version 0.5.0 (3635 buckets, 14540 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
zynq_pm_ioremap: no compatible node found for ‘xlnx,zynq-ddrc-a05’
zynq_pm_late_init: Unable to map DDRC IO memory.
Registering SWP/SWPB emulation handler
hctosys: unable to open rtc device (rtc0)
ALSA device list:
No soundcards found.
RAMDISK: gzip image found at block 0
EXT4-fs (ram0): couldn’t mount as ext3 due to feature incompatibilities
EXT4-fs warning (device ram0): ext4_update_dynamic_rev:746: updating to rev 1 because of new feature flag, running e2fsck is recommended
EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
EXT4-fs (ram0): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr,errors=remount-ro
devpts: called with bogus options
ubi0: attaching mtd2
ubi0: scanning is finished
ubi0: attached mtd2 (name “configs”, size 8 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 7/3, WL threshold: 4096, image sequence number: 1468506214
ubi0: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
ubi0: background thread “ubi_bgt0d” started, PID 729
UBIFS (ubi0:0): background thread “ubifs_bgt0_0” started, PID 733
UBIFS (ubi0:0): recovery needed
UBIFS (ubi0:0): recovery completed
UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name “config_data”
UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi0:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS (ubi0:0): reserved for root: 275879 bytes (269 KiB)
UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 61DD06EC-F5DB-4203-9351-AEDD5BEDE4F3, small LPT model
ubi2: attaching mtd4
ubi2: scanning is finished
ubi2: attached mtd4 (name “reserve1”, size 14 MiB)
ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi2: good PEBs: 112, bad PEBs: 0, corrupted PEBs: 0
ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi2: max/mean erase counter: 6/3, WL threshold: 4096, image sequence number: 1730002810
ubi2: available PEBs: 0, total reserved PEBs: 112, PEBs reserved for bad PEB handling: 4
ubi2: background thread “ubi_bgt2d” started, PID 740
UBIFS (ubi2:0): background thread “ubifs_bgt2_0” started, PID 744
UBIFS (ubi2:0): recovery needed
UBIFS (ubi2:0): recovery completed
UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name “misc”
UBIFS (ubi2:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi2:0): FS size: 11935744 bytes (11 MiB, 94 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS (ubi2:0): reserved for root: 563754 bytes (550 KiB)
UBIFS (ubi2:0): media format: w4/r0 (latest is w4/r0), UUID A114C21F-937B-48F6-932A-C38FEE473A65, small LPT model
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
random: avahi-daemon urandom read with 2 bits of entropy available
macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
macb e000b000.ethernet eth0: link up (100/Full)
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
In axi fpga driver!
request_mem_region OK!
AXI fpga dev virtual address is 0xcfbc8000
*base_vir_addr = 0xb031
In fpga mem driver!
fpga mem virtual address is 0xd2000000
random: nonblocking pool is initialized
===========================================Miner log===========================================
1970-01-01 00:00:09 Invalid config option --bitmain-freq: ‘’ is not a number
1970-01-01 00:00:09 Invalid config option --bitmain-voltage: ‘’ is not a number
1970-01-01 00:00:09 Invalid config option --bitmain-ccdelay: ‘’ is not a number
1970-01-01 00:00:09 Invalid config option --bitmain-pwth: ‘’ is not a number
1970-01-01 00:00:09 Miner compile time: Fri Dec 11 11:23:44 CST 2020 type: Antminer S19 Pro
1970-01-01 00:00:10 This is fix-freq version
1970-01-01 00:00:10 Miner compile time: Fri Dec 11 11:23:44 CST 2020 type: Antminer S19 Pro
1970-01-01 00:00:10 commit version: 1821c90 2020-11-16 16:05:37, build by: jenkins 2020-12-11 11:35:43
1970-01-01 00:00:10 opt_multi_version = 1
1970-01-01 00:00:10 opt_bitmain_ab = 1
1970-01-01 00:00:10 mid_auto_gen = 0
1970-01-01 00:00:10 opt_bitmain_work_mode = 0
1970-01-01 00:00:10 mmap fpga_mem_addr_hal = 0xb5900000
1970-01-01 00:00:10 HASH_ON_PLUG V9 = 0x7
1970-01-01 00:00:10 Note: front fan is power on!
1970-01-01 00:00:10 Note: rear fan is power on!
1970-01-01 00:00:10 start the http log.
1970-01-01 00:00:10 httpListenThread start ret=0
1970-01-01 00:00:10 start listen on 6060 …
1970-01-01 00:00:10 load machine NBP1901 conf
1970-01-01 00:00:10 machine : NBP1901
1970-01-01 00:00:10 chain_num 4, chain_domain_num 38, chain_asic_num 114, domain_asic_num 3
2021-06-17 13:41:47 miner ID : 8044f40457104814
2021-06-17 13:41:47 FPGA Version = 0xB031
2021-06-17 13:41:47 HASH_ON_PLUG V9 = 0x7
2021-06-17 13:41:47 ==========================capability start==========================
2021-06-17 13:41:47 board num = 3
2021-06-17 13:41:47 board id = 0, chain num = 1
2021-06-17 13:41:47 chain id = 0
2021-06-17 13:41:47 board id = 1, chain num = 1
2021-06-17 13:41:47 chain id = 1
2021-06-17 13:41:47 board id = 2, chain num = 1
2021-06-17 13:41:47 chain id = 2
2021-06-17 13:41:47 ==========================capability end============================
2021-06-17 13:41:47 chain num = 3
2021-06-17 13:41:49 [chain 0]
2021-06-17 13:41:49 0x0000 11 4A 2E 13 20 13 63 25 05 B1 BD B9 4A 21 5B 0A
2021-06-17 13:41:49 0x0010 9C 80 5F FB 03 68 71 0C 84 FB 10 5A 59 93 C8 FC
2021-06-17 13:41:49 0x0020 8E BA 2F 3D 4C B1 13 3F F0 EE 9D 2A B0 14 32 81
2021-06-17 13:41:49 0x0030 CE 6D 64 4F BB 6D 16 B7 AE 00 DB F1 D8 D2 3A AF
2021-06-17 13:41:49 0x0040 2C 83 1B 0A A9 BF CD F4 AE 9C FF FF FF FF FF FF
2021-06-17 13:41:49 0x0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:49 0x00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 5A
2021-06-17 13:41:49
2021-06-17 13:41:51 [chain 1]
2021-06-17 13:41:51 0x0000 11 4A 2F D1 99 EA A1 E7 6E 3D B4 62 FB D1 EC B4
2021-06-17 13:41:51 0x0010 0F 63 32 FB 2E 10 40 68 2B 56 0C A1 EE 7D 4D 40
2021-06-17 13:41:51 0x0020 4A 68 BD 8E 65 19 18 36 64 FB 1E B8 53 62 73 BE
2021-06-17 13:41:51 0x0030 92 3F A5 11 F2 F9 DC DD 0D 90 5D 5A 88 4C 92 B2
2021-06-17 13:41:51 0x0040 97 BA CF 56 94 54 26 C3 1A 74 FF FF FF FF FF FF
2021-06-17 13:41:51 0x0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:51 0x00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 5A
2021-06-17 13:41:51
2021-06-17 13:41:53 [chain 2]
2021-06-17 13:41:53 0x0000 11 4A 39 7A C6 FF 0E 9A 13 3C D5 25 74 57 61 AB
2021-06-17 13:41:53 0x0010 51 9F B1 B5 B2 CD 9A 43 E5 72 47 67 EB 57 98 E8
2021-06-17 13:41:53 0x0020 23 1B FE CC 4A 0F 21 87 E8 A1 F6 AA E0 FF 3D B5
2021-06-17 13:41:53 0x0030 6D 5F 5C BD B4 8E 6D 59 B1 2A 5E 5B 1F 06 8C 9A
2021-06-17 13:41:53 0x0040 E1 5A CF A5 56 DF FA E7 34 6A FF FF FF FF FF FF
2021-06-17 13:41:53 0x0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
2021-06-17 13:41:53 0x00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 5A
2021-06-17 13:41:53
2021-06-17 13:41:53 fan_eft : 0 fan_pwm : 100
2021-06-17 13:41:53 create thread
2021-06-17 13:41:53 fixed working voltage = 1280
2021-06-17 13:41:53 Chain [0] PCB Version: 0x0100
2021-06-17 13:41:53 Chain [0] BOM Version: 0x0100
2021-06-17 13:41:53 Chain [1] PCB Version: 0x0100
2021-06-17 13:41:53 Chain [1] BOM Version: 0x0100
2021-06-17 13:41:53 Chain [2] PCB Version: 0x0100
2021-06-17 13:41:53 Chain [2] BOM Version: 0x0100
2021-06-17 13:41:57 Fan check passed.
2021-06-17 13:41:58 chain[0] PIC jump to app
2021-06-17 13:41:59 Check chain[0] PIC fw version=0x89
2021-06-17 13:42:00 chain[1] PIC jump to app
2021-06-17 13:42:02 Check chain[1] PIC fw version=0x89
2021-06-17 13:42:03 chain[2] PIC jump to app
2021-06-17 13:42:05 Check chain[2] PIC fw version=0x89
2021-06-17 13:42:05 create thread
2021-06-17 13:42:05 max sensor num = 4
2021-06-17 13:42:05 temperature_monitor_thread start…
2021-06-17 13:42:09 power type version: 0x0071
2021-06-17 13:42:09 Enter sleep to make sure power release finish.
2021-06-17 13:42:40 Slept 30 seconds, diff = 2.
2021-06-17 13:42:40 set_voltage_by_steps to 1500.
2021-06-17 13:42:42 power reply the bad crc, crc = 0x0092, crc_read = 0x92ff
2021-06-17 13:42:42 read_back_data[0] = 0x55
2021-06-17 13:42:42 read_back_data[1] = 0xaa
2021-06-17 13:42:42 read_back_data[2] = 0x06
2021-06-17 13:42:42 read_back_data[3] = 0x83
2021-06-17 13:42:42 read_back_data[4] = 0x09
2021-06-17 13:42:42 read_back_data[5] = 0x00
2021-06-17 13:42:42 read_back_data[6] = 0xff
2021-06-17 13:42:42 read_back_data[7] = 0x92
2021-06-17 13:42:42 Send power cmd(0x83) failed, retry 0
2021-06-17 13:42:47 start up min temp by 75a = 20
2021-06-17 13:42:47 set UART baud to 115200
2021-06-17 13:42:50 chain avg vol rise to 15.26
2021-06-17 13:42:55 Chain[0]: find 114 asic, times 0
2021-06-17 13:43:03 Chain[1]: find 114 asic, times 0
2021-06-17 13:43:07 !!! REG_TYPE = 1. 805894145
2021-06-17 13:43:11 Chain[2]: find 114 asic, times 0
2021-06-17 13:43:11 pulse_mode = 1, ccdly_sel = 0, pwth_sel = 0
2021-06-17 13:43:15 min freq in eeprom = 525
2021-06-17 13:43:15 fixed frequency is 525
2021-06-17 13:43:15 Bring up temperature is 20
2021-06-17 13:43:15 set UART baud to 12000000
2021-06-17 13:43:16 set_voltage_by_steps to 1280.
2021-06-17 13:43:23 STATUS_INITED: soc init done!
2021-06-17 13:43:23 create thread
2021-06-17 13:43:26 start to init…
2021-06-17 13:43:34 Init done!
2021-06-17 13:43:34 STATUS_OKAY
2021-06-17 13:43:34 start the cached job
2021-06-17 13:43:34 Version num 8
2021-06-17 13:43:34 Mask num 0xe000
2021-06-17 13:43:34 freq = 525, percent = 90, hcn = 12480, timeout = 449
2021-06-17 13:43:34 set_start_time_point total_tv_start_sys=124 total_tv_end_sys=125
2021-06-17 13:43:34 set_voltage_by_steps to 1305.
2021-06-17 14:13:23 avg rate is lower than ideal rate, 3918.05 in 29 mins
Hey Christopher, my names Wes. Can you point me in the right direction to purchase a decent asic miner. Just starting out and scared to get scammed. Any advice would be much appreciated.
Was this solved with a new PSU?
can you share what u did to get it working i am having the same issue with mine???
