Hello everyone,
I need help with setting up ETH+ZIL split mining on my T-Rex miner in HiveOS. I can’t figure out what extra config arguments I need to add in my T-Rex Miner to make it work.
At this time, I’m running a GPU mining rig with 11 Nvidia cards (each one has at least 8GB of VRAM and no LHR) and I’m using HiveOS ver. 0.6-211@211117 with Nvidia Drivers 460.67. Furthermore, I’m using the HIVEON pool to mine ETH and the Ezil pool to mine ZIL.
Also, I’ve been successfully split mining ETH+ZIL with the Windows 10 version of T-Rex miner, but I can’t figure out how to make it work in HiveOS version. The config for the WIndows version of T-Rex miner is below.
t-rex.exe -a ethash --coin eth+zil -o stratum+tcp://use-eth.hiveon.net:4444 -u 0x8ffffffffffffffffffffffffffffffffffffffe -p x -w WORKER01 --url2 stratum+tcp://eu.ezil.me:5555 --user2 0x8ffffffffffffffffffffffffffffffffffffffe.zil1ffffffffffffffffffffffffffffffffffffff.WORKER01 --extra-dag-epoch 0
I’ve done a lot of searching on YouTube and Google, and I can’t find any updated tutorials (in the last 30 days) that give you a step by step process on setting up split mining without a proxy. Can you help a fellow miner out?
-Jeb
