Need Mining Pool coder for Vallor (VDS) V-Dimension (existing open source script) Minerstat top coin
This coin seems to be the most profitable coin on minerstat. I have worked through all the BS and settled on gminer 1.44. After running through a few errors and fixing a couple of other issues with the miner and windows I got it running. Now there are no pools that I can find. Not great with coding but I know that V-Dimension now has open source script to create a pool. I have or can get whatever hardware is necessary and currently have 500mbps internet speed with unlimited un-throttled data. Not static but that can be changed if needed. I have access to open fiber if needed. Is there any interest in the community to partner on a pool. My hardware and your coding 50/50 dev fees. PLEASE note no matter what you find, uupool, vvpool, 666pool, f2pool pools do not work anymore. if you know of others please post.
