Hey everyone, trust you guys are keeping safe, are you guys running a segrenated networking for your miners? If yes, what’s the config you’re running.
I try to use SSL if the pool’s server will allow. I have some miners on a separate subnet with IP switching and some on the base subnet without cloaking. Since some pools request your WAN IP address, cloaking and switching probably don’t help. That’s why I prefer SSL, but the configuration is easy on some mining software, and more difficult if not impossible on other mining software provided the pool has SSL and a separate port. Ideas/suggestions would be nice!
I’m thinking to get a few switches and setting up and setting up SUBNET’s and VLAN. I’m still what else I can do. Thanks for your insight very helpful, if I come across anything I’ll surely share.
Apologies but I thought this category best suited the subject. After all, it’s about Mining, safety and hardware/software we can use for it.
