Neuron CKB wallet
I recently set up a neuron wallet for my ck box to mine into. I find it odd that there is no login or logout. It does require password before making withdrawal. What is annoying is that there is no way for multiple people to use the same pc to access their individual neuron accounts. Is that right??
Thanks
my experience is slightly different. it always prompts for password only when doing a transaction. the password is for the wallet access on that machine only. you can see the other wallets but cant do anything if you don’t have the password. I find it odd there doesn’t seam to be a way to remove a wallet.
