Has anyone mined into Neuron wallet? Any issues? I recently transferred a balance without issue to put into DAO, however, when I mined to the account it says it was a success but I have a zero balance.
I mine to neuron. I’ve never had a problem. Some times it just takes a bit to sync to get the up to date balance
Yeah, I mine into neuron also with no problems. If the pool says that it has paid out and you dont see it then I would check to make sure you’ve entered the correct address. Also, make sure the wallet is fully synced.
Thank you it was my lack of patients. It took a little while but it’s all good now.
