First time posting here,
I’m trying to set up a new S19 Pro and connect it to slush pool. I can’t get slush pool to add my miner as well as I’m getting the red fault light flashing on the miner. Within the S19 start up dashboard it’s showing “Chip state abnormal” as well as “Network state abnormal”.
Fan speed, hash rate, temp are all green and normal. Ethernet connection seems good to go and I restarted the miner from the Bitmain dashboard. Any thoughts on this?
Thanks for any help
Quick update,
I had my miner worker name different and did not realize they need to be the same on both ends. Problem solved. Rocking out 114HT at the moment.
Did you ever figure this out? I’m having the same problem.
