Newb issues with setting up merge mining wallet address for PEP, LKY and BELLS
Just got my first miner and trying to set up merged mining in F2Pool.
Have tried to follow the guides but I think there is a problem between the chair and the keyboard.
I seem to be stuck trying to find anything that supports a wallet for PEPE Coin (PEP), Lucky Coin (LKY) and BELLS (BELLS).
My Tangem wallet does not support them and not sure if you can create a custom wallet or not.
I checked coinbase and they have a wallet supported for lucky coin but not the others.
Q) Do I really need to have multiple wallets with different systems/hardware just to cover these 3 coins? Am I missing something here?
I saw the last Vosk video on using mining dutch and they allow you to choose which coin the merged mining is paid out in so that may be a solution however I am keen to use F2pool as I just set it up.
Tips welcome, thanking you in advance for any guidance.
Hi, What miner are you using?
Elphadex dg home1
I think Drew uses Exodus for the LTC & Doge. But uses nonkyc for some of the others.
I use an address on my nonkyc account for Bells, LKY, PEP & JKC then set f2pool to (Payouts pause) until Tangem or another wallet I use supports it.
So if you set payout pause you accumulate all the coins and they are held until you un-pause it and allocate a wallet?
Thanks for the info on nonkyc looks good although it says luckycoin is being delisted, any tips for storing luckycoin?
