Hi. I am very new and love your YouTube vids. I’m in the UK and severly disabled and have a little savings.very little. I want to try mining. I can get Bitcoin BTC Miner Whatsminer M3 for £115. I only have my house and conservatory. Have you got any recommendations? Hi to Tails.
I wouldn’t recommend an m3 unless you have free power. I, am not an expert (On anything really) so don’t take this as financial advice. 2.2kw is quite a bit of power for 12.5th which, at a 0.06$ USD electric rate, is currently doing about -2.14$ Bitcoin isn’t a very beginner friendly thing to get into mining. I would suggest something smaller, and less power hungry. Cheers! You can also check the asic section of www.whattomine.com very helpful.
