There is no correct answer to that question. If you want fast ROI you will need to be a good bargain hunter and find the cheapest parts for the mining rig you are looking to build. But the power supply is not something you want to cheap out on. I would go for atleast a good gold one. As for reasonably priced GPUS good luck with that one they are hard to come by these days.
