About got my vent ran . Using pipe tubing covers to run my exhaust line. By code the vent has to always run downhill so we’ll see how it does. Have a few more cans of foam to use to make sure everything is sealed. Hopefully the noise is cut down.
If noise is still bad, you could buy a couple Noctua fans. I’ve found them to be quieter
