If you’re unsatisfied or struggling with your connection or having mining issues use this tool to help you, it’s free and gets the job done, first build a custom list it will take 30 mins then run the benchmark and test the top 10, hopefully it helps, for me it’s essential
Not familiar with the tool but looks like it is related to DNS so my suggestion would be instead to just change your DNS to one of the better options particularly if you are using your ISP provided DNS.
Yep that’s what this sexy tool does, when you do the “build a custom list” it grabs like the top 50 dns servers for your router exclusively then you run a test and voila
