So I decided to switch over my HS Box to Sia tonight. Why? I don’t know. I’ve been switching back and forth every couple of weeks because I can I guess. I started messing with the miner settings and did the “fast click 10 times” on “Miner” in miner tab to get to the hidden settings. I did this on Handshake mode a bit and got it to average 255gh/s pretty easy. I thought what the heck since it doesn’t draw much power in Sia mode I’d push it harder. I’ve got it set now to 950mhz and 0.46V. Fan setting the same. Been running about 30 min and I think the average will settle somewhere around 580-590gh/s. Not getting any hotter than normal. Fans are around 1300 rpm but it is in cold garage. I guess we will see how this goes. Any higher th he errors start racking up. Maybe it will work. Maybe I’m an idiot. At any rate I’m going to go “check on it” in garage. Can’t help it I have to pass beer fridge on my way there. Better check on it too….
Cool. Thanks for sharing.
What’s the mining profits look like?
Gave it one more little nudge to 962mhz. A couple points shy of 600gh/s. Showing $1.18/day at current price.
Hi Wedge77, what was the original settings and the final you ended up with and what was your Hashrate, errors, and rejects, at both settings? Did you change overclocking and voltage by the same percentage?
